2001 Daewoo Lanos Car problems
2001 DAEWOO LANOS
CANDYGIRLBABYJ
2001 Daewoo Lanos 4 cyl 57,250 miles
My car has been in the shop for several months back and forth it is iddling very off and it has very bad gas mileage. They have hooked it up to the computers many times and nothing ever comes up. The engine is very loud and sounds like I am driving a gigantic diesal pickup. I have spent 600.00 at the mechanic and nobody can figure out the problem, and it is still happening. Any ideas?
Jun 26, 2008 at 2:42 PM
BMRFIXIT
  • 19,053 POSTS
Have the timing belt check and pulleys
Jul 6, 2008 at 6:44 AM
CANDYGIRLBABYJ
[quote:306b273d6b="BMRFIXIT"]Have the timing belt check and pulleys[/quote:306b273d6b]
I have already had the timing belt replaced as well as everything with it about 1 year ago when the belt broke and ruined everything attached to it. Any other ideas would be helpful.
Jul 7, 2008 at 7:13 PM
BMRFIXIT
  • 19,053 POSTS
VALVE ADJUSTMENT
Engine specifications will indicate valve train clearance and temperature at which adjustment is to be made on most models. In most cases, adjustment will be made with a cold engine. In some cases, both a cold and a hot clearance will be given for maintenance convenience.
On some models, adjustment is not required. Rocker arms are tightened to specification and valve lash is automatically set. On some models with push rod actuated valve train, adjustment is made at push rod end of rocker arm while other models do not require adjustment.
Clearance will be checked between tip of rocker arm and tip of valve stem in proper sequence using a feeler gauge. Adjustment is made by rotating adjusting screw until proper clearance is obtained. Lock nut is then tightened. Engine will be rotated to obtain all valve adjustments to manufacturer's specifications.
Some models require hydraulic lifter to be bled down and clearance measured. Push rods of different length can be used to obtain proper clearance. Clearance will be checked between tip of rocker arm and tip of valve stem in proper sequence using a feeler gauge.
Overhead cam engines designed without rocker arms actuate valves directly on a cam follower. A hardened, removable disc is installed between the cam lobe and lifter. Clearance will be checked between cam heel and adjusting disc in proper sequence using a feeler gauge. Engine will be rotated to obtain all valve adjustments.
On overhead cam engines designed with rocker arms, adjustment is made at valve end of rocker arm. Ensure valve to be adjusted is riding on heel of cam on all engines. Clearance will be checked between tip of rocker arm and tip of valve stem in proper sequence using a feeler gauge. Adjustment is made by rotating adjusting screw until proper clearance is obtained. Lock nut is then tightened. Engine will be rotated to obtain all valve adjustments to manufacturer's specifications.
Jul 7, 2008 at 9:20 PM
