2000 Daewoo Lanos door lock
2000 DAEWOO LANOS
X!LAURA!X
Electrical problem
2000 Daewoo Lanos Manual
Someone has put a screwdriver in the driver side of the car in the lock. The car locks fine inside and from the passenger side, however the key cant be used to lock the door. How much would this cost to repair?
Apr 23, 2009 at 3:34 AM
NOIR RESURECTION
  • 5 POSTS
If there is a broken piece inside the key hole or the key hole was damaged then you may need to get a locksmith to take off the lock itself and have him remove the broken piece. If they damaged it then you may need to replace the whole lock and then have a locksmith recode the lock so it can work with the original key so you wont have 2 different keys. If thats the case then your looking at anywhere from $75 to $150 depending on what they charge in your area.
May 18, 2009 at 2:29 AM
