2000 Daewoo Lanos changed master and slave still no shift
2000 DAEWOO LANOS
91,000 MILES • 4 CYL • FWD • MANUAL
I have changed the master and slave clutch cylinders and it now builds pressure but still will not shift i don't get it any help would be great
Jan 9, 2009 at 2:43 PM
Did you properly bleed the system after you installed the M/C and the slave-if so -you have a problem with the clutch assembly.
Jan 9, 2009 at 2:56 PM
yes i think i bled it properly had someone pump then hold clutch then opened bleed valve. But nothing was wrong when the slave went out.
Jan 9, 2009 at 7:09 PM
Did you bleed the slave/servo? If so get helper to step on the clutch a few times, while you look at the slave push rod is it moving and engaging the clutch fork.
Jan 10, 2009 at 1:25 PM
