1998 Daewoo Lanos timing belt replacement
1998 DAEWOO LANOS
179,800 MILES • 4 CYL • FWD • MANUAL
TARGET
I have a 1.5ltr are there any special tools that I need to replace the timing belt. Do I need a timing belt tension gauge. How do I tell if the belt is at right tension, because the manual is telling me that the tension is set by the coolant pump, then the auto tensioner is installed.
Nov 26, 2009 at 1:05 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There is a special tool required to rotate the water pump (No. J42492)You turn the pump anti clockwise until the tensioner pointer is aligned with the marker on the support plate.
Mark (mhpautos)
Nov 26, 2009 at 3:33 PM
