1998 Daewoo Lanos daewoo
1998 DAEWOO LANOS
HALEY37
  • 12 POSTS
Other Category problem
1998 Daewoo Lanos Engine Size unknown Wheel Drive Type unknown Manual 73000 miles
any1 tell me wat the firing order is for daewoo lanos 1.4 1998 is thanx
Dec 30, 2007 at 11:25 AM
Are you sure its 1.6L instead of 1.4L
Dec 30, 2007 at 11:42 AM
HALEY37
  • 12 POSTS
[quote:d1c277e9db="rasmataz"]Are you sure its 1.6L instead of 1.4L[/quote:d1c277e9db] its 1.4s
Dec 30, 2007 at 11:45 AM
HALEY37
  • 12 POSTS
[quote:4aaea65610="rasmataz"]Are you sure its 1.6L instead of 1.4L[/quote:4aaea65610] sorry lanos s 1.4
Dec 30, 2007 at 11:49 AM
The firing order is 1342 rotation dunno-but if you remove the distributor cap and crank engine over look at the direction the rotor is turning and follow it.
Dec 30, 2007 at 11:52 AM
HALEY37
  • 12 POSTS
[quote:ad1e35a340="rasmataz"]The firing order is 1342 rotation dunno-but if you remove the distributor cap and crank engine over look at the direction the rotor is turning and follow it.[/quote:ad1e35a340] cant do that as its coil pack if you know wat i mean
Dec 30, 2007 at 11:53 AM
I've been trying to come up with it on the auto references software am using-but won't give or no info is to the wiring position on the packs. Am afraid that you need to get a repair manual for it locally or see below in regards to manual and download it for a cheap price.
Thanks for visiting 2carpros-Happy New year
Dec 30, 2007 at 12:05 PM
HALEY37
  • 12 POSTS
[quote:cd3c452462="haley37"][quote:cd3c452462="rasmataz"]The firing order is 1342 rotation dunno-but if you remove the distributor cap and crank engine over look at the direction the rotor is turning and follow it.[/quote:cd3c452462] cant do that as its coil pack if you know wat i mean[/quote:cd3c452462]ok thankyou
Dec 30, 2007 at 12:22 PM
HALEY37
  • 12 POSTS
[quote:fabd40d822="rasmataz"]I've been trying to come up with it on the auto references software am using-but won't give or no info is to the wiring position on the packs. Am afraid that you need to get a repair manual for it locally or see below in regards to manual and download it for a cheap price.
Thanks for visiting 2carpros-Happy New year[/quote:fabd40d822] i have spark and can here pump running but dose not wont to start can please help as miss is getting pissed off with me lol
Dec 30, 2007 at 12:33 PM
Put some gas in the throttle body and try to start it. If not were right back to square one with coil packs-we need the coil firing sequences.
Dec 30, 2007 at 1:54 PM
HALEY37
  • 12 POSTS
[quote:639f1b6d80="rasmataz"]Put some gas in the throttle body and try to start it. If not were right back to square one with coil packs-we need the coil firing sequences.[/quote:639f1b6d80] if you can help with coil fire sequuances il b most gratful as cant buy online no bank thanx
Dec 30, 2007 at 2:59 PM
I'll keep looking for how the coil packs are wired with the plugs.
Dec 30, 2007 at 3:02 PM
HALEY37
  • 12 POSTS
[quote:1c16c06cbf="rasmataz"]I'll keep looking for how the coil packs are wired with the plugs.[/quote:1c16c06cbf] thankyou very much your a star by the way wat is diode fuse as was coroded will clean it and try tomoz
Dec 30, 2007 at 3:43 PM
