1996 Daewoo Cielo Oil Change
1996 DAEWOO CIELO
PLANDLESS
Engine Mechanical problem
1996 Daewoo Cielo Front Wheel Drive Manual
How do I change the motor oil in my Daewoo Cielo?
Mar 20, 2010 at 12:57 AM
Use the correct oil vicosity and amount as specified warm the engine up for 10mins find the oil drain plug-open it-be careful its hot and let it drain till the last drop comes out-tighten back the oil drain plug. Put the amount of quarts needed to the full mark-if correct start the car up and look at the drain plug if its leaking. Your done
Mar 20, 2010 at 3:36 AM
