1996 Daewoo Cielo CRANKS BUT WONT START
1996 DAEWOO CIELO
180,000 MILES • 4 CYL • FWD • MANUAL
RUDIGER
REPACED HEAD , REPLACED DISTRIBUTER BLACK BOX IN DISTRIBUTER , REPLACED ECM WHEN DIDNT START , GOT FUEL TO INJECTORS , NO FUEL GOING THROUGH INJECTORS ,NO POWER TO INJECTOR WIRES , NO SPARK TO ENGINE , COIL HAS POWER , ROTOR BUTTON NEW , CAP TESTED AND FINE , FUSES FINE , NEED HELP , UNEMPLOYED AND NEED CAR TO GET WORK , SPENT TOAL SAVING TO GET TO THIS POINT , WOULD DONATE IF HAD ANY MONEY LEFT
Mar 5, 2010 at 9:11 PM
MARK HOWE
  • 6 POSTS
i have a 1996 daewoo cielo and im also have an issue with the car not starting just cranking over sometimes but most times it starts i would like to no also what could be wrong with why sometimes it cranks over but does not want to start at times and also does anyone no where the ecm or ecu computer thing is in the daewoo cielo please.
Oct 9, 2016 at 7:48 PM
Hey,
It sounds like you may have a compression problem, I would start by removing the spark plugs to check to see if they are fouled. Then I would double check the timing belt to make sure you got the timing belt on right.
Here is a guide that will help you.
The ECM should be under the dash on the left side.
Please let us know happens so it will help others.
Best, Ken
Nov 22, 2016 at 6:10 PM
