Cylinder location for cylinder two misfire
2007 KIA OPTIMA
150,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
BRIANPAULF
  • 4 POSTS
I am having a cylinder 2 misfire. I am not sure which cylinder that is. I believe it is the far left one closest to the radiator, but the guy at AutoZone thought it was the furthest left closest to the closer the body. If anyone knows for sure which cylinder is number two i would appreciate it.
Is this the correct order of the cylinders?
135
246
Jun 6, 2020 at 2:03 PM
Good afternoon,
I attached the cylinder order for you.
The front bank is 2-4-6.
As far as the misfire, make sure you test the compression.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
General Description
Misfires can be caused by lack of combustion in a cylinder due to absence of spark, poor fuel metering, poor compression, or many other causes. Even a small number of misfires may result in excessive exhaust emissions due to the unburned mixture. Increased misfire rates cause damage to the catalytic converter. The PCM monitors the crankshaft speed variation to determine if any misfiring generated. The PCM identifies the specific cylinder in which the misfire has occurred and counts individual misfire events by monitoring changes in the crankshaft rotation for each cylinder. A random misfire indicates two or more cylinders are misfiring.
DTC Description
The PCM measures reference event times and calculates the positive and negative acceleration of the crank wheel to determine whether a misfire has occurred.
When the rate of misfire exceeds a threshold where the catalyst reaches a temperature where permanent damage can occur. PCM sets this DTC. In case that misfire affects Catalyst damage, MIL (Malfunction Indication Lamp) will be illuminating and blinking at 1 Hz frequency. However, In case of Individual and Emission damaging misfire, MIL will be turned on when the malfunction is detected.
Especially, if injector connector is disconnected for more than 46 secs., PCM sets DTC relating to misfire and conducts the fuel-cut to protect the catalyst.
Jun 6, 2020 at 2:14 PM
BRIANPAULF
  • 4 POSTS
That is the correct firing order. I figured it out. Ended up being the ignition coil.
Jun 6, 2020 at 2:23 PM
BRIANPAULF
  • 4 POSTS
Thank you so much for the information. I switched the coils around and the code changed to the other cylinder. Once again, thank you so much for the time and information. I greatly appreciate it.
Jun 6, 2020 at 2:24 PM
You are welcome.
Always glad to help.
Jun 6, 2020 at 2:32 PM
