You need two tools. A 100% sure straight edge and a set of feeler gauges. Lay the straight edge on the head gasket surface, parallel to the length of the head. Pick a .004 inch (.1 mm) feeler gauge. Now use the gauge to check along the length of the straight edge between it and the head. You do not want the gauge to slide through.
Do this in three to four places and be sure to check the areas between cylinders closely.
Now measure diagonally across the surface as well.
Here is a good video on it:
https://www.youtube.com/watch?v=u4SzK_OjAkY
Oct 23, 2017 at 9:47 AM
