Cylinder head problem
2005 AUDI A4
147,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
TONYP247
  • 5 POSTS
Hi, I've recently changed the head on my car listed above 20tdi. I put it all back together but when I bolt the injector rail down the cams lock up. I've changed the shell bearings encase it was that, but still no joy. please help it's really stressing me out.
Feb 22, 2019 at 5:03 AM
That is an interesting one. I am going to provide the directions for removing and replacing the head and injectors. See if there is anything you may have missed. All pictures correlate with these directions.
_________________________________________
Cylinder Head, Removing and Installing
Vehicle Engine, Cooling and Exhaust Engine Cylinder Head Assembly Service and Repair Procedures Cylinder Head, Removing and Installing
CYLINDER HEAD, REMOVING AND INSTALLING
Cylinder head, removing
Special tools, testers and auxiliary items required
Picture 1
^ Drip tray for workshop crane VAS 6208
^ Counter-holder tool 3036
^ Puller T40001
^ Puller T40039
^ Hose clamp pliers V.A.G 1921
Pin wrench T10020
Picture 2
Drift T40098
Picture 3
Removing
^ Engine installed.
Note:
^ All cable ties which are opened or cut open when removing, must be replaced in the same position when installing.
^ If oil is dirty, perform an oil change:
^ When using sealant, observe the current descriptions.
- Note radio code (for vehicles equipped with coded anti-theft radio / radio navigation system), obtain if necessary.
Picture 4
- Remove engine cover - arrows -.
CAUTION: Cover cap of expansion tank with rag and open carefully, as hot steam or hot coolant may escape when opening.
- Open cap of coolant expansion tank.
Picture 5
- For vehicles with auxiliary heater, remove bolts - arrows - for exhaust pipe of parking heater/auxiliary heater on sound insulation.
Picture 6
- Loosen quick-release fasteners - 1 - and - 2 - and remove front sound insulation.
- Drain engine coolant
- Remove toothed belt.
Picture 7
- Loosen bolt for camshaft sprocket using counter-holder 3036.
Picture 8
- Pull off camshaft sprocket using two-arm puller T40001 and claw T40001/6 and claw T40001/7.
Picture 9
- Remove rear toothed belt housing from cylinder head - arrows -.
Picture 10
- Disconnect Ground (GND) cable - 1 -.
- Disconnect vacuum line to brake booster at bulkhead - 2 -.
- Disconnect EVAP hose - 3 -.
Picture 11
- Remove coolant hoses - 1 and 2 - and unfasten coolant expansion tank - arrow -
- Disconnect electrical connection at Engine Coolant Level (ECL) Warning Switch F66 at bottom of coolant expansion tank.
Picture 12
- Disconnect electrical connector from Charge Air Pressure Sensor G31 - 1 -.
- Remove left charge air hose - 2 -.
Picture 13
- Remove air duct hose - 1 - to turbocharger at bottom right.
- Remove air duct hose - 2 - to charge air cooler at lock carrier.
Picture 14
- Disconnect connector - 1 and 2 - and free up cable.
Picture 15
- Unfasten oil supply line for turbocharger at cylinder block - 1 -.
- Remove bolt - 2 - of support for turbocharger.
Picture 16
- Remove oil supply line for turbocharger - arrows -.
Picture 17
- Disconnect oil return line - arrows - from turbocharger.
Picture 18
- Loosen support bolt - 1 - for turbocharger by 2 turns.
- Remove intake manifold
- Remove catalytic converter
- Remove cylinder head cover
Picture 19
- Loosen cylinder head bolts, paying attention to sequence of cylinder head bolts.
Note: Verify that all hose and line connections between engine, transmission and body have been disconnected.
- Remove cylinder head.
Cylinder head, installing
Note:
^ Replace cylinder head bolts.
^ Always replace self-locking nuts, bolts which have been tightened to tightening torque as well as gaskets and O-rings.
^ Secure all hose connections using hose clamps appropriate for the model type.
^ Carefully remove residual sealant from cylinder head and cylinder block. Make sure that no long scrapes or scratches result.
^ Thoroughly remove all grinding and sanding residue.
^ Only unpack new cylinder head gasket immediately prior to installation.
^ Handle gasket carefully. Damages to the silicone layer and in areas of recesses may result in leaks.
^ There must be no oil or coolant in the blind holes for the cylinder head bolts in the cylinder block.
^ High-temperature lubricant
CAUTION: Only turn over the engine at the crankshaft in direction of engine rotation (clockwise).
Note: Turning over the engine is performed at the central bolt of the crankshaft.
Picture 20
- Bring marking on camshaft gear to alignment with marking on toothed belt guard. Recesses - arrows - now point to each other vertically.
- In case the crankshaft was turned in the meantime: Set piston of cylinder 1 to TDC and turn crankshaft back again slightly.
Picture 21
- Set cylinder head gasket in place.
^ Pay attention to centering pins in cylinder block - arrows -.
^ Observe installed position of cylinder head gasket, Marking: Replacement part number must be legible from intake side.
- Set cylinder head in place.
- Insert cylinder head bolts and tighten by hand.
Picture 22
- Tighten cylinder head in sequence indicated, in two stages as follows:
- Tighten with torque wrench:
^ 1. Step: 40 Nm
- Tighten using a solid wrench:
^ 2. Step: 180° (1/2 turn) further (2 x 90° further is permissible)
Note: There is no requirement to retighten the cylinder head bolts after repairs.
- Install cylinder head cover.
- Install toothed belt.
- Install ribbed belt.
- Electrical connections and routing:
- Install the intake manifold
- Connect battery.
- Bleed fuel system.
- Check oil level.
- Fill with coolant.
Note:
^ Only reuse drained coolant if cylinder head or engine block was not replaced.
^ Dirty coolant must not be re-used.
- Install lock carrier with attachments.
Picture 23
- Place torque support stop onto rubber buffer for torque support under its own weight and tighten nuts - arrows -.
- Install front bumper cover.
- Check headlight adjustment.
CAUTION: Do not use a battery charger for starting assistance! There is the risk that the vehicle control modules could be damaged.
Torque specifications
Picture 24
_______________________________________________
Fuel injector
Fuel Injectors, Removing And Installing
Removing
Remove intake manifold and fuel rail.
Removing fuel injectors, in the event that they are stuck in the fuel rail
Carefully pull fuel injectors out of the fuel rail.
Removing fuel injectors, in the event that they are stuck in the cylinder head
Picture 25
- Tool set with puller T10133 Tool Set T10133
Picture 26
The illustration shows the fuel injector.
1 - Radial compensation, replace if damaged
2 - Combustion chamber sealing ring (Teflon sealing ring). Replace the sealing ring once removed. The sealing ring must not be greased or handled with any other lubricants when installing.
3 - Groove on fuel injector
4 - Spacer ring, replace if damaged
5 - O-ring (replace, coat lightly with clean engine oil when installing)
6 - Support ring (via this support ring, the fuel rail utilizes the force to hold the fuel injector in place in the cylinder head).
Picture 27
NOTE: With fuel injector installed, the radial adjustment - 1 - is clipped into the support ring - 6 - . To remove the fuel injector, the support ring must be separated from the fuel injector in order to install the puller T10133/2 into the indentation on the fuel injector - 3 - .
- Cover open intake channels with a clean rag.
- Disconnect electrical harness connector at fuel injector that is to be removed.
Picture 28
- Bend retaining tabs of radial compensation to the side using a screwdriver and pull off support ring from fuel injector.
Picture 29
- Assemble the slide hammer T10133/3 - 1 - and the injector puller T10133/2 - 2 - . Then, guide the puller T10133/2 into the groove on the fuel injector and carefully drive the fuel injector out. It is possible that this will destroy the radial compensation (retaining tabs break). This must be replaced when re-installing fuel injector.
NOTE: The combustion chamber seal must always be replaced before re-installing the fuel injector.
Fuel Rail
Fuel Rail, Removing and Installing
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Rail Service and Repair Removal and Replacement Fuel Rail, Removing and Installing
FUEL RAIL, REMOVING AND INSTALLING
Fuel Rail, Removing And Installing
If fuel rail is to be replaced, the Intake Manifold Runner Position Sensor G336 must be adapted to the Engine Control Module (ECM) J623 again, "Guided Functions"
NOTE: Intake manifold must be removed.
- Remove hoses from EVAP canister.
- To do so, open hose clamp - 1 -.
Picture 30
- Remove both bolts - arrows - from fuel rail.
- Remove hose connection 1 from intake manifold and remove both bolts - arrows - .
Picture 31
- Remove both fuel lines - 2 and 3 - .
- Carefully pry off linkage from Intake Flap Motor V157 - 4 - .
Picture 32
- Remove Intake Flap Motor V157 - 5 -.
Picture 33
- Pry fuel rail off from the intake manifold via the retaining tabs - arrows - .
- Remove fuel rail from intake manifold.
Installing
- Installation is in reverse order of removal.
- Install intake manifold.
Feb 22, 2019 at 11:23 PM
TONYP247
  • 5 POSTS
Hi there, thanks for your reply. I've done everything in your step by step guide, but I don't know if it makes any difference, but my car is twin cam 16V.
Feb 23, 2019 at 1:04 AM
Welcome back:
If I understand, when you install the fuel rail/injectors, the cams lock up. Can you see anything that is making contact? That doesn't really make sense.
Are you using all the same hardware (bolts) to reinstall?
Feb 23, 2019 at 4:34 PM
TONYP247
  • 5 POSTS
I'm using all new bolts and the only thing that makes contact is the injector rockers. If I loosen the bolts that hold the rail down the cams turn freely it's doing my head in and help would be so appreciated many thanks tony
Feb 24, 2019 at 7:21 AM
Do me a favor, take a picture of where it is hitting, where it bolts. anything you can think of that may help. If they are touching when bolted, something is missing. Are you sure there were no spacers? Take a look at picture 1 and tell me what is touching the cam. You have me confused because the injectors shouldn't be near the cam. They are on the side of the engine under the intake. See picture 1. Picture 2 is of the injector. Which part is hitting?
Feb 24, 2019 at 4:17 PM
TONYP247
  • 5 POSTS
This is my engine so you understand what I'm talking about. The injectors are in between the two cams. I've sent a picture of the injector rail removed.
Feb 25, 2019 at 2:11 AM
Here are the directions I have. Let me know if they help. Something isn't aligning when you do the install.
Installing
NOTE:
- Install a new Pump-Injector Unit, also replace the corresponding adjustment bolt in rocker arm.
- For each step which requires an adjustment of Pump-Injector Unit, adjustment bolt in rocker arm and also the ball pin for Pump-Injector Unit must be cleaned and examined for traces of wear. If there is wear, ball pin and adjustment bolt must be replaced.
- Grease contact surface between ball pin and adjustment bolt with G 000 100.
- New Pump-Injector Units are shipped with O-rings and heat protection seal.
- If old Pump-Injector Unit is re-installed, the O-rings and heat protection seal must be replaced.
- Before installing Pump-Injector Unit, check that the three O-rings, heat protection seal and securing ring are seated properly.
NOTE: O-rings must not be twisted on themselves.
- Oil O-rings and insert Pump-Injector Unit with great care into cylinder head seat.
- Drive Pump-Injector Unit in using uniform pressure into cylinder head seat until stop.
- Insert tension block into lateral slot of Pump-Injector Unit.
NOTE: If Pump-Injector Unit does not stand at right angle to tension block, securing bolt can loosen and thereby cause damage to Pump-Injector Unit / cylinder head.
- Align Pump-Injector Unit as follows.
- Screw in the new securing bolt as far into tension block so that the Pump-Injector Unit can still be turned lightly.
- Now align Pump-Injector Unit at right angle to thrust bearing of camshaft.
- Using a caliper gauge (measuring range minimum 400 mm), check dimension "a" from outer edge of cylinder head to round surface of Pump-Injector Unit.
- Re-align Pump-Injector Unit if necessary and tighten securing bolt as follows:
- Tighten securing bolt to 12 Nm and 270 degree (3/4 turn) (additional rotation can occur in several stages).
- Install rocker arm axle and tighten new securing bolts as follows:
- Tighten inner bolts -2- hand-tight, then outer bolts -1-. Then in the same sequence,
Tighten to 20 Nm plus an additional 90 degree (1/4 turn).
- Set a dial gauge onto adjustment bolt of Pump-Injector Unit
- Rotate crankshaft in direction of engine rotation until rocker arm roller stands at camshaft top.
Roller side (arrow -A-) stands at highest point
Dial gauge (arrow -B-) stands at lowest point
- Remove dial gauge.
- Now turn adjustment bolt into rocker arm until significant resistance is noticeable (Pump-Injector element stands at stop).
- Turn back adjustment bolt from stop approx.
225 degree.
- Hold adjustment bolt in this position and tighten lock nut to
30 Nm.
- Connect connector to Pump-Injector Unit and install cylinder head cover and toothed belt guard.
See if this helps.
Feb 25, 2019 at 7:58 PM
TONYP247
  • 5 POSTS
Tried everything but still locking up.
Feb 28, 2019 at 1:59 PM
Wow. If everything is going together straight, all components are installed correctly, the only thing I can think of is something is bent.
Feb 28, 2019 at 5:49 PM
