cylinder head gasket thickness?
1996 FORD F-150
180,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
FORDSMB454
  • 42 POSTS
hi, i have a quick question, I'm doing a top end rebuild on the truck listed above 302 all stock my question is i bought a FEL-PRO 9333 PT-1 Head Gasket and Fel-Pro Performance Head Gaskets 1011-2 so 2 different gaskets so 1 head has PT-1 other head has Fel-Pro Performance Head Gaskets 1011-2 is this ok? They both fit i assume, just the thickness of gaskets. or should i just do both heads PT-1 or both PT-2? or is it okay to leave it with both having 2 different gaskets.
Jul 5, 2024 at 1:25 PM
Using two different head gaskets on a 1996 Ford F150 5.0 302 (one Fel-Pro 9333 PT-1 and one Fel-Pro Performance 1011-2) is not recommended.
Thickness Difference:
Use the same type of gasket on both cylinder heads. Given that you have both the Fel-Pro 9333 PT-1 and Fel-Pro Performance 1011-2 gaskets
Let us know if you need anything else.
Jul 5, 2024 at 4:35 PM
