I bought a new Tundra and added a CNG system immediately. The truck ran fine for about 25k miles until the check engine light appeared. It checked out perfectly at dealership. They would only check it while running on gasoline. Took it to CNG installer and he ended up replacing entire CNG system with no luck in getting light to stay off. CNG installer even moved coil to see if misfire would move....it didn't move. Cylinder 7 is the only culprit. I believe that something is going on in cylinder 7 that has no effect while on gas, but causes a light while running on CNG. The check engine light usually stays solid, but occasionally blinks at which time I turn off truck and turn it back on and light goes solid again. The CNG installer did make the CNG fuel leaner which did make the engine light mainly stay solid. Before this adjustment the light would start blinking with very regular annoyance.
Aug 23, 2014 at 9:14 PM
