Initially I got a code for throttle positioning sensor error followed by a code for a cylinder 5 misfire. TPS code never reappeared. Then I replaced the spark plugs and Ignition coils in all 6 spaces as well as the fuel intake gasket. Also replaced a upper coolant hose due to a leak. After this code went away for about 30 minutes of driving and then came back. added fuel additive still driving on it. code clears runs fine about half an hour afterwards but every time code comes back and shaking while idling and low RPMs (about 1200-1500) persists. I'm believing it's a fuel injector issue but this code disappearing and reappearing is unnerving.
One other symptoms is dimming dash and headlights during shaking bouts. Vacuum pressure is consistent.
Any ideas?
Any ideas?
Mar 10, 2021 at 1:58 PM
