I think it's a wiring issue as well. I'm trying to locate this C101 connector. See if you can locate this ground G102 (third diagram). The c101 connector is just the five wires for the solenoids.
The fourth diagram is the OEM with the connectors and splices we need to be concerned with. s115 s136 and connector c101
The fifth diagram shows s115 (splice) that's on the ground side, so anything on the ground side is of concern because it will cause all four solenoids or circuits to fail any self-tests.
Ok the seventh diagram is c101 on the driver side rear of the engine, that's the connector with all five of the wires for the MDS solenoids. The Black wire with a Brown stripe is the ground. It should have continuity to ground even with the key off.
But after the c101 connector the wire runs to the c100 connector then finally to its ground location g102, they have it running through multiple connectors for some reason. But it's a black/brown wire the whole way.
I know I keep adding things here, but the 10th diagram is a quick ground test at any of the connectors with a test light hooked to battery positive. Since this wire is always grounded it should light the test light with the key off.
Oct 19, 2022 at 2:09 PM
