Okay, been looking at the fuel system and your symptoms. Get the fuel pressure checked and also run a volume test. I am suspicious that you have a clogged fuel filter or the pump is failing. Another remote possibility is that you have water or other contamination. That would have to go through the injection system and would cause many of the problems you are seeing.
If possible could you post the actual numbers for the codes. They might point to a fault or better idea of the problem.
Do you notice if this happens only when the fuel gets below a certain level? Only after it is parked for a while? Or is it all the time?
Feb 15, 2017 at 3:39 PM
