Hi, last month I checked the engine oil level and I saw that it was over full even though I never added any oil and in March when I did the oil change at Walmart it was exactly full and I also noticed that the engine oil had a red color at the bottom of the oil level dipstick, is the CVT transmission leaking CVT fluid into the engine oil and if it does will the CVT fluid dilute the engine oil and decrease its lubricating value and damage the engine? I can't check the CVT fluid because it's a sealed system and it doesn't have a transmission fluid dipstick like the older model cars used to have, the CVT transmission also makes a whining noise while operating and has delayed acceleration, how long will it last before it fails completely and no longer drives the car? thanks in advance for your information, Alex Stathas
May 11, 2023 at 9:53 AM
