CVT Transmission?
2014 MITSUBISHI OUTLANDER SPORT
170,000 MILES • 4 CYL • 4WD • AUTOMATIC
RSIZER92
  • 4 POSTS
When traveling on the interstate over seventy-five miles per hour the transmission overheats under seventy-five miles per hour no issues appear.
Jul 12, 2025 at 12:01 PM
Oh yes, that is because the fluid needs to be changed, when the fluid wears out the transmission will slip causing this "overheating" here is how to change the fluid and only use.
Transmission fluid dm3 (qt) Mitsubishi Motors Genuine CVTF-J4 7.1 (7.5)
Fill in the new transmission fluid through the filler tube. Check out the images (below). Let us know how it goes.
Jul 12, 2025 at 7:14 PM
RSIZER92
  • 4 POSTS
Changed the fluid. Very easy to do. Engine sounds better no more whining or slipping so far. Thank you.
Jul 21, 2025 at 8:13 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime.
Jul 21, 2025 at 10:27 AM
