Hello, I have a blinking D and I tried to measure the voltage on the CVT start clutch pressure control valve connector terminal 1 using a multimeter, when I turn on the key the voltage increases from 0v to about 6.85v and then drops once to 0.01v and stays on 0.01v until I turn off the key and then turn it on and again it increases up to about 6.85v and drops once to 0.01v. Is this normal? If not, what am I supposed to do to fix this?
There is continuity on terminal 2.
It's a Honda Airwave 2005 with a CVT transmission.
Feb 23, 2022 at 10:16 AM
