Noise in the front left wheel, possible CV Joint?
2011 TOYOTA TACOMA
71,000 MILES • 4WD
BMCAULIFFE
My truck started making a clunking noise 2 days ago in the front left tire. I don’t really notice it in relation to braking or accelerating, it just seems to happen somewhat randomly either braking or accelerating or driving normally. Definitely notice it when the truck shifts as in going over a bump or rough road. Last time I took it in a few months ago I was told the CV joint in that tire had “a lot of play” and recommended replacing it soon.
Would this be a good guess at the cause of the noise? Would it be a hard job for someone with no mechanical experience? Would I need specialty tools? The videos I’ve watched don’t make it look crazy hard, but could I be getting in over my head, and save the headache and take it to a pro?
I would love to learn to work on my truck but again, have no experience and not a ton of tools. Thanks for any advice.
Oh, and if you don’t think it would be caused by CV joint, what other suggestions do you have?
Mar 1, 2021 at 12:29 PM
Often times a CV joint will make a clicking sound when making a sharp turn. Have you noticed that at all? I'm curious because you indicated it makes the sound over bumps. To me, that sounds more like a suspension noise such as a broken or weak shock, ball joint, and so on. Have you checked any of those things?
As far as a CV joint/axle replacement, it really isn't too hard. It does require a few special tools, but not many. Keep in mind, most parts stores will lend you tools. What they do oftentimes they charge you for the tool and then refund you when it's returned.
First, here is a link that shows how it's done in general. You can use this as a guide.
https://www.2carpros.com/articles/replace-cv-axle
Here are the directions specific to your vehicle. The pics below correlate with the directions.
___________________________________________________
2011 Toyota Truck Tacoma 4WD L4-2.7L (2TR-FE)
Removal
Vehicle Transmission and Drivetrain Drive Axles, Bearings and Joints Axle Shaft Assembly Service and Repair Removal and Replacement Front Drive Shaft Assembly Removal
REMOVAL
DRIVE SHAFT: FRONT DRIVE SHAFT ASSEMBLY (for 4WD): REMOVAL
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
2. REMOVE FRONT WHEEL
3. DRAIN DIFFERENTIAL OIL
4. SEPARATE FRONT SPEED SENSOR
pic1
(a)Remove the bolt and separate the front speed sensor.
(b)Disengage the 2 clamps.
(c)Remove the bolt and separate the speed sensor wire harness from the steering knuckle.
5. SEPARATE TIE ROD END SUB-ASSEMBLY
(a)Remove the cotter pin and nut.
(b)Using SST, separate the tie rod end from the steering knuckle.
pic 2
SST : 09628-62011
6. REMOVE FRONT AXLE HUB NUT
pic 3
(a)Using a screwdriver and a hammer, remove the front axle hub grease cap.
(b)Remove the cotter pin and adjusting cap.
pic 4
(c)Remove the front axle hub nut.
7. SEPARATE FRONT SUSPENSION LOWER ARM
pic 5
(a)Remove the 2 bolts and separate the front lower ball joint attachment front from the steering knuckle.
8. REMOVE FRONT DRIVE SHAFT
pic 6
(a)Using SST, remove the front drive shaft.
SST : 09520-01010
SST : 09520-24010
09520-32040
NOTICE:
Be careful not to damage the oil seal.
___________
Install
Installation
Vehicle Transmission and Drivetrain Drive Axles, Bearings and Joints Axle Shaft Assembly Service and Repair Removal and Replacement Front Drive Shaft Assembly Installation
INSTALLATION
DRIVE SHAFT: FRONT DRIVE SHAFT ASSEMBLY (for 4WD): INSTALLATION
1. INSTALL FRONT DRIVE SHAFT
pic 7
(a)Coat the spline of the inboard joint shaft with ATF.
(b)Align the shaft splines and install the drive shaft with a brass bar and hammer.
NOTICE:
* Set the snap ring with the opening side facing downward.
* Be careful not to damage the oil seal.
HINT
Whether the inboard joint shaft is in contact with the pinion shaft or not can be confirmed from the sound or feeling when driving it.
2. INSTALL FRONT SUSPENSION LOWER ARM
pic 8
(a)Install the front lower ball joint attachment with the 2 bolts.
Torque : 160 Nm (1,631 kgf-cm, 118 ft-lbf)
3. INSTALL FRONT AXLE HUB NUT
pic 9
(a)Install the hub nut.
Torque : 235 Nm (2,396 kgf-cm, 173 ft-lbf)
(b)Install the adjusting cap and a new cotter pin.
(c)Install the front axle hub grease cap.
4. INSTALL TIE ROD END SUB-ASSEMBLY
(a)Install the tie rod end onto the steering knuckle.
(b)Install the nut.
Torque : 91 Nm (928 kgf-cm, 67 ft-lbf)
(c)Install a new cotter pin.
5. INSTALL FRONT SPEED SENSOR
pic 9
(a)Install the speed sensor wire harness onto the steering knuckle with the bolt.
Torque : 13 Nm (133 kgf-cm, 10 ft-lbf)
(b)Engage the 2 clamps.
(c)Install the speed sensor with the bolt.
Torque : 8.3 Nm (85 kgf-cm, 73 in-lbf)
6. INSTALL FRONT WHEEL
Torque : 113 Nm (1,152 kgf-cm, 83 ft-lbf)
7. ADD DIFFERENTIAL OIL See: Fluid - Differential > Adjustments > Differential Oil
8. INSPECT DIFFERENTIAL OIL See: Fluid - Differential > Adjustments > Differential Oil
9. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL
Torque : 3.9 Nm (40 kgf-cm, 35 in-lbf)
See: Vehicle > Technician Safety Information > Repair Instruction - Precaution
10. CHECK VSC SENSOR SIGNAL (w/ VSC)
for Hydraulic brake booster See: Antilock Brakes / Traction Control Systems > Scan Tool Testing and Procedures > Test Mode Procedure
for Vacuum brake booster See: Antilock Brakes / Traction Control Systems > Scan Tool Testing and Procedures > Test Mode Procedure
11. CHECK ABS SENSOR SIGNAL (w/o VSC)
12. CHECK FOR DIFFERENTIAL OIL LEAKAGE
13. INSPECT AND ADJUST FRONT WHEEL ALIGNMENT
See: Alignment > Procedures > Front Wheel Alignment (for 4WD and Pre-Runner)
As far as doing it, if you take your time and follow the directions, you should be fine. But, you have to be comfortable doing it. I will be here to help as much as I can.
Take care and God Bless,
Mar 1, 2021 at 6:56 PM
