CV axle replacement
2012 VOLKSWAGEN JETTA GLI
132,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
DIMITRIR
I'm trying to replace my factory passenger side CV axle, and this is the second one I've ordered, and it isn't the exact same as the factory. the middle bar is a little thinner, the same length screws slight shorter though I was wondering if the replacement has to be the exact same.
Jan 14, 2022 at 1:35 PM
SQM
  • 6,383 POSTS
Are you talking about the center shaft part? (Look at picture below, circle in red)
Is the spline the same size?
If you just have the different diameter for the center part, but all the other dimensions and measurements are the same then it will work. The shaft can be thinner due to the material or production capabilities.
Please let me know.
Thank you.
https://www.2carpros.com/articles/replace-cv-axle
Jan 14, 2022 at 2:34 PM
