I'm replacing driver side CV axle. The retaining clip that holds it in the trans-axle didn't pop out and I pulled shaft that's attached and runs into the trans-axle out some. I don't know how the get CV axle separated from this shaft without pulling this shaft all the way out with it. is it okay to pull this shaft all the way out? I know your not supposed to do both axles at once cause removing both at same time allows gears to fall in and trans-axle overhaul will result. But I don't know the inner working at all to know if I did damage by shaft coming along with CV axle. Am I in trans-axle trouble?
Dec 20, 2018 at 10:37 AM
