Cv axle significant vibration?
2019 HYUNDAI VELOSTER
120,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SAMMYQ1967
I changed out the CV axle and now I have significant vibration at speeds and excess of 40 mph
Mar 19, 2026 at 12:15 PM
STEVE W.
  • 15,113 POSTS
If this started right after you changed out the shaft then it's very possible the shaft you installed is bent or defective. I would check that it seated fully in the transaxle and that it is seated in the hub and doesn't have play. Was it an OE or aftermarket part? Why was it replaced?
Mar 20, 2026 at 6:38 AM
