Yes it can. If the joint in the CV axle is binding then it can cause it to do this. However, I would want to confirm the axle is the issue before replacing it.
Can you give a little detail about how you are testing this? Are you lifting just one wheel or are both front tires off the ground when you are checking it?
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Normally they start clicking first but if the tire doesn't spin, we need to eliminate the other possible causes first.
Let me know and we can go from there. Thanks
Aug 21, 2020 at 8:03 AM
