Had someone replacing both front axles, he pulled them both at the same time. But never finished the job, my husband goes to finish an finds that the drivers side axle is jammed in. Upon getting it out, it was damaged. Got the new one and went to put it in, find that there is causing it to jam up. We consulted with a retired mechanic and he says that when you pull both axles at the same time, the bar that connects the two axles will fall.
So my questions are; Is this true? If so, can it be fixed and how do you fix it?
Nov 11, 2017 at 1:43 PM
