Hello, it's been a while. But I've got an issue with my car listed above GXE 2.4L. I just replaced the passenger side cv axel. This is my first and hopefully my last. First of all, I replaced the Hub and the bearings lower control arm sway bar link and new Cardone axel lifetime warranty. This has been a challenge to say the least. I've had to buy several new tools including an impact wrench due to a froze up axel nut. Anyway after buying all the parts to repair the passenger side I got it all back together and thought I did everything right watched a video and learned a few things but I started the car the front end is on stands so I start it up put it in drive and the axel I replaced barely turns while the driver side is turning very fast. So, I went through taking it all apart again Now I'm stuck not knowing what to do. I spent around $350.00 so far and can't afford another 500.00 to a local mobile mechanic. I'm a fairly good DIY mechanic but this being my first CV replacement I'm not sure what's going on. I noticed a faint noise coming from what I think was the Transmission. They sold me an ABS Axel and mine doesn't have ABS. I've measured the shaft going into the transmission from the seal to the tip of the shaft and the old one is the same measurement. Could it be the inside of the axel not going all the way into the inside of the transmission? You cannot get close enough to tell if the seal is flush with the housing. The car was manuf. 11/97. They double checked the part with VIN and said it's the right part. Sorry, this is so long but I've had really good info from you guys in the past. The other thing is I think the middle part of the shaft that has the three 12 mm bolts that bolt to the transmission bracket I think it's a little bit shorter than the original axel when I pulled the axel back out after replacing it I could see where the shaft stopped inside the transmission from the lubrication I put on the splines before I put it in. Please let me know if anyone knows what's going on or if they have run into this problem. Thanks. JC.
May 25, 2023 at 5:48 PM
