The car started cutting out while driving. The check engine light came on so I took it and had AutoZone check it with their code reader it said I had a misfire so I changed the plugs. The plugs have never been changed until now. After I change the plugs it was still cutting out and the check engine light came back on I took it again to have them put their code reader on it and it said EGR valve I replaced it. The car will idle smooth when you take off it is still cutting out. Any help would be greatly appreciated thank you in advance.
Feb 16, 2019 at 8:11 PM
