Cutting out under load full, steering lock?
2007 MAZDA CX-7
242,600 MILES • 2.3L • 4WD • AUTOMATIC
RMILZ0010
My car vehicle above US idling rough with low jumpy revs, when A/C is on, and I lock steering full either way the car stalls. Have replaced every sensor, new timing kit, coils, plugs, leads, fuel pumps everything. Any ideas?
Feb 4, 2023 at 1:50 AM
Yep, this happens when you have a vacuum leak, or the throttle body needs to be serviced. here are two guides to help us fix the problem with instructions for you can in the images below:
and use this guide when the engine is cold only.
Feb 4, 2023 at 12:19 PM
RMILZ0010
Will this also no speed build up (limp mode)?
Feb 4, 2023 at 2:43 PM
Yes, in limp mode the engine will not rev. have you run the trouble codes?
This guide can help:
Please go over this guide and report back.
Feb 5, 2023 at 1:23 PM
RMILZ0010
Have used an obd2 and no codes at all.
Feb 5, 2023 at 3:20 PM
I have seen a bad throttle bore or throttle pedal sensor go out and cause this issue with no codes. I would try cleaning the throttle bore first. Check out the images (below). Please let us know what happens.
Feb 6, 2023 at 1:04 PM
