PCM swap
1998 FORD F-150
377,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JAMESBURROW
  • 46 POSTS
Will a power control module (PCM) computer out of a 2001 ford F150 5.4l work in my truck listed above as long as i take it to the ford dealership and have it reprogrammed?
Jul 27, 2020 at 7:31 AM
Good morning,
It must be the exact number of the one you are replacing and you have about a 50-50 chance of it taking the program. Sometimes it works fine and other times it does not.
Jul 27, 2020 at 7:56 AM
BMDOUBLE
  • 1,139 POSTS
It used to work with previous program levels of the diagnostic software, but the last time that I tried doing a PCM swap it didn't work, but some techs keep their own laptops with older versions that might work.
Jul 27, 2020 at 8:00 AM
JAMESBURROW
  • 46 POSTS
what would you recommend i do ?
Jul 27, 2020 at 8:06 AM
If you need an ECM, I would get a new one and have it flashed to your VIN.
What makes you think you need an ECM?
Jul 27, 2020 at 8:21 AM
JAMESBURROW
  • 46 POSTS
Because when I got the truck the idle would go up and down randomly and I would be driving it and all the sudden it would lose power and then kick back in randomly. then a couple of months later one day it started running rough and it didn't have any power at all a week. after that I was going down the road and the truck shut off and wouldn't start back up. it would turn over but not even try to start. I plug a code scanner up to it and it just says error. the day after it broke down the battery was dead and it was a new battery. oh, and it seemed like it took a long time to shift gears.
Jul 27, 2020 at 9:13 AM
JAMESBURROW
  • 46 POSTS
No, it will turn over but wont even try to start.
Jul 27, 2020 at 12:47 PM
Okay, you need fuel pressure, spark and compression.
Can you hear the fuel pump run with the key on?
When you crank the engine, does it show RPM on the tachometer on the dash? That will tell me if the crank sensor is working.
Compression would be last.
Jul 27, 2020 at 12:55 PM
JAMESBURROW
  • 46 POSTS
No, the rpm doesn't move at all. When i turn the key on i hear 2 clicks under the dash it sounds like something is trying to turn on but then it turns back off.
Jul 27, 2020 at 12:59 PM
JAMESBURROW
  • 46 POSTS
And no i don't hear the fuel pump come on when i turn the key on. i have already changed the fuel pump and filter, because i thought it was going out.
Jul 27, 2020 at 1:01 PM
Okay, we need to do some testing. Do you have a voltmeter and a test light?
We need to check some powers at the power relay and the fuel pump relay.
Jul 27, 2020 at 1:18 PM
JAMESBURROW
  • 46 POSTS
Yes sir, i have both a voltmeter and a test light, but i'm at work right now i get off at 5:00 so I will be home around 6:30. can we continue this diagnostic test when i get home ?
Jul 27, 2020 at 1:37 PM
Tonight will be fine.
Jul 27, 2020 at 1:41 PM
JAMESBURROW
  • 46 POSTS
Okay, thank you so much. you don't know how much i appreciate this.
Jul 27, 2020 at 1:42 PM
BMDOUBLE
  • 1,139 POSTS
Pop the hood and on the driver side, open the fuse box cover and give this relay a tap. If it starts or stalls when you tap it, try swapping it with it's neighbor. Very very very common!
Jul 27, 2020 at 2:30 PM
As he said, that is the power relay that controls all power to the fuel pump relay and a lot of other components that I highlighted in the diagrams I sent you.
Jul 27, 2020 at 3:12 PM
JAMESBURROW
  • 46 POSTS
Okay, so I checked all my fuses and I found a couple of them that were blown so I replaced them and my truck started and stayed running but it still has no power. it idles when i have it in park just fine but once I put it in gear it it idles real low and tries to shut off. When i'm driving the engine runs rough like it has a couple of cylinders misfiring and when I give it gas it acts like it has a vacuum leak. i have to barely touch the gas pedal little by little and let it build up speed it takes me about 1 1/2 miles to get up to 35 mph.
Jul 29, 2020 at 4:28 AM
Okay, you need to go back to my original suggestions and check the fuel pressure. That is the start.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
https://www.2carpros.com/articles/engine-has-low-power-output
I also suspect the exhaust is clogged from cat converters. You could get a back pressure gauge or you could loosen the head pipes from the manifolds and then drive the truck and see if power returns.
Jul 29, 2020 at 4:39 AM
JAMESBURROW
  • 46 POSTS
It's not the catalytic converters. I got some off another truck and swap them out and still the same problem. I found a plug towards the back of the motor on top that is not plugged into anything not sure what it's for. I was wondering if maybe you knew.
Jul 29, 2020 at 7:56 AM
Can you post a picture for me of the plug?
Also, did you check the compression in a cylinder or 2 to see if the valve timing jumped?
I would not rule out the exhaust. I would drop the front pipes and start it and drive to be sure the rest of the system is not restricted.
Jul 29, 2020 at 8:58 AM
JAMESBURROW
  • 46 POSTS
Okay, so I took the exhaust off and started it up and it still runs rough.
Jul 29, 2020 at 8:29 PM
Okay, did you check the compression in number 2 as well?
Did some of the power return with the pipes disconnected?
The pipes will not cause the rough running. It will cause the lack of power. The running rough needs to be checked by checking the compression. The misfire may have damaged the cats from unburned fuel in the exhaust and overheating the catalytic converters.
Jul 30, 2020 at 3:20 AM
JAMESBURROW
  • 46 POSTS
There is that pic of the plug that's not connected.
Jul 30, 2020 at 7:58 AM
JAMESBURROW
  • 46 POSTS
Sorry wrong pic. but I was wondering what that was it's on my transmission and it has oil all over the plug wire I was wondering if maybe that caused it to go out.
Jul 30, 2020 at 7:59 AM
JAMESBURROW
  • 46 POSTS
Here's the pic of the plug:
Jul 30, 2020 at 8:00 AM
JAMESBURROW
  • 46 POSTS
And no I haven't done any compression test yet. I'm going to do it when I get home from work.
Jul 30, 2020 at 8:01 AM
Where is that connector located and what colors are the wires?
Jul 30, 2020 at 8:04 AM
JAMESBURROW
  • 46 POSTS
I figured out where the plug went; it's one of my knock sensors. I changed the idle control valve and now my truck runs a lot better, it's still missing in cylinder 3 and when i take off i can feel it kind of jerking a little. like something is working and then not working, but if i hold the gas pedal in a certain spot then it is okay.
Jul 31, 2020 at 6:29 AM
Got it. Let me know the results of the compression test.
Jul 31, 2020 at 6:31 AM
JAMESBURROW
  • 46 POSTS
And also when the motors cold when I take off it cuts out totally for about 5 seconds and then kicks back in.
Jul 31, 2020 at 7:30 AM
Okay, let us see the compression test next and then we will continue.
Jul 31, 2020 at 7:32 AM
JAMESBURROW
  • 46 POSTS
And it won't idle. when I have it in gear it tries to shut off if I put it in park it's okay.
Does it idle in reverse?
Can you run the engine above idle?
https://www.2carpros.com/articles/stall-at-idle
I would check the throttle body for any carbon build up.
Jul 31, 2020 at 7:41 AM
JAMESBURROW
  • 46 POSTS
I had someone check them for me and he said all of them are around 90 except one is at 85.
Jul 31, 2020 at 11:58 AM
That is no good. It should be 140-160.
You either have a chain, tensioner or guide issues with the chain or worn valves.
Jul 31, 2020 at 12:07 PM
JAMESBURROW
  • 46 POSTS
I was wondering if you could tell me what makes my gas pedal vibrate once I get my RPM's up high.
Aug 13, 2020 at 9:23 AM
Most likely from engine misfiring.
Did you get the compression fixed?
Aug 13, 2020 at 9:31 AM
JAMESBURROW
  • 46 POSTS
I think i figured out the problem. one of my shift solenoids went out; it says shift solenoid A. now I just need to find out which transmission my truck has so I can order the solenoid. do you have any idea ?
Sep 3, 2020 at 12:27 PM
Your truck came with the E4OD transmission.
You should have a deep pan.
Sep 3, 2020 at 12:33 PM
JAMESBURROW
  • 46 POSTS
If the computer says shift solenoid A is bad does it mean i need to change my shift solenoid pack? because I don't see a shift solenoid anywhere.
Sep 3, 2020 at 7:43 PM
