Brake caliper torque specifications
2016 HOLDEN CRUZE
40,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
TIKIBREMJO
Hi, I was wondering if you can help me with finding the Torque specs for the caliper bracket bolts on the car listed above JH Series II sedan. I would presume that they should be the same as the Chevrolet Cruze, but I am not completely certain of this. Also, are the caliper bracket bolts Torque to Yield (TTY) bolts? If so, do they need replacing once they have been removed? Thank you in advance for any help you can offer. Cheers.
Sep 20, 2018 at 10:13 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Those bolts can be re-used. First pass torque to 110 Ft Lbs. Final Pass torque an additional 45 Ft Lbs. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 21, 2018 at 10:51 AM
TIKIBREMJO
Sorry Danny, just a little confused. If the first pass torque is 110 Ft Lbs and the final pass is an additional 45Ft Lbs, does this mean after the first pass I add an additional 45Ft Lbs to make it 155Ft Lbs for the final pass? Or did you mean first pass 110Ft Lbs and second pass +45deg? Sorry to be a pain, but I really want to get this right. Thanks again for your help. Cheers, Tim.
Sep 23, 2018 at 4:56 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, first pass 110 Ft Lbs and then second pass to 155 Ft Lbs total. Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 23, 2018 at 9:26 PM
