Okay. If it isn't working at all, it could be a servo, module, cable, switch, and so on. I am going to provide the diagnostics related to checking the switch and then the unit. Before you get started, make sure to check the fuses listed at the end of the diagnostics listed.
______________________
2005 Hyundai Truck Santa Fe V6-2.7L
Component Tests and General Diagnostics
Vehicle Sensors and Switches Sensors and Switches - Cruise Control Cruise Control Switch Testing and Inspection Component Tests and General Diagnostics
CRUISE CONTROL MAIN SWITCH
1. Operate the switch and check for continuity between the terminals.
pic 1
2. If continuity is not as specified, replace the switch.
________________________________________________________
Vehicle Cruise Control Testing and Inspection Component Tests and General Diagnostics
TROUBLESHOOTING
see pic 2
NOTE: Before troubleshooting:
- Check the No.4 (10 A), No.14 (10 A), No.19 (10 A) fuse In the passenger compartment relay box.
- Check ECU #3 (10 A) fuse in the engine compartment relay box.
- Check that the horn sounds.
- Check the tachometer to see if it works properly
Jul 16, 2020 at 2:26 PM
