Cruise control only will turn on and set speed but no other buttons work like the cancel, resume or coast. Any thoughts. Thanks.
Nov 27, 2019 at 5:06 AM
CERTIFIED EXPERT
This is most likely one of two things. Either the switch itself or the clock spring. The way we test this is to remove the switch and test for voltage when pressing the buttons. However, if you look at the wiring diagram I am confident that the switch is the issue because each of the buttons share a feed through the clock spring. So if the Set button is working then that would indicate the clock spring is okay.
Let me know what you think and we can go from there.
Image (Click to enlarge)
Nov 27, 2019 at 5:12 PM
PHEONIX
MEMBER
Thanks for the advice. I will take the car to the mechanic to check. One more question, how much should I pay to get this checked?
Nov 28, 2019 at 2:57 PM
CERTIFIED EXPERT
That depends on the shops door rate but if this is the issue and they need to replace the switch and their rate is $100.00 per hour, it should be around $325.00. That is about an hour of diag, 4 hours to replace it and the part is about $178.00.
