Cruise control not working or lighting up on dash
2001 CHEVROLET IMPALA
90,000 MILES • 4.8L • 6 CYL • 2WD • AUTOMATIC
CODYCLARK247
Try to use cruise control and I can't get it to work. Checked fuses and none are bad..
Apr 21, 2020 at 7:54 PM
Good morning,
Is the ABS light on in your car? If it is, it will disable the cruise system as it uses the signal from the sensors to control the cruise.
I attached a wiring diagram for you to view. Can you get a test light or voltmeter to do some testing?
Apr 22, 2020 at 4:25 AM
