Mechanic could not find any trouble codes. Cruise control ECU would not register. for $75.00 replaced brake switch did not solve the issue. Looked online and saw that there is a cruise control ECU. Found used for $20.00. Unable to find out the mounting location to swap out online. Can someone let me know the location or where I can find the location online? Car is 20 years old and runs good. I will get all the required maintenance done. Trying to fix cheap if possible otherwise will live without.
Symptom.
Turns on when button is pushed. When the "set" button is pushed, the cruise light will blinks.
Symptom.
Aug 5, 2020 at 7:15 PM
