Cruise control cable
2004 HYUNDAI SANTA FE
264,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
LUCEY2
I am changing the plugs and wires. I have to remove the plenum. I loosened the cruise control and throttle cable where it is attached to hold in place but the cruise control cable is still in the way. I cannot see the side towards the back of the car to see how to remove the cable from the throttle body to get it out of the way to remove the plenum.
May 28, 2018 at 11:46 AM
KHLOW2008
  • 41,814 POSTS
The cable is attached similar to the picture below. You need to turn the cable further up and slot it out of the groove to disconnect. If all else fails, you can either leave it and wait until the plenum is removed to disconnect or remove the throttle body first.
May 28, 2018 at 8:06 PM
LUCEY2
Thank you, now understand with the picture.
May 29, 2018 at 9:15 PM
STEVE W.
  • 15,113 POSTS
Just checking to see how you have progressed on your repairs or if you have not had time.
May 31, 2018 at 12:50 PM
