Creak / squeak from driver side front wheel over bumps / hard right turns
2012 HONDA CIVIC
50,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
MIDWEST-DAVE
  • 22 POSTS
Recently I noticed that while going over more pronounced bumps on the road (at highway speed) or taking a sharp right turn going 30-40mph there is what sounds like a creak / squeak coming from the driver's side front wheel well. It sounds metallic and only happens on right turns at the speeds indicated above.
Some background: Last week while the vehicle was parked, something backed in to it causing a grapefruit sized dent on the driver's side front fender and causing the steering to turn 90 degrees right from center. The vehicle drives fine, isn't out of alignment, the brakes feel fine and are not sticking, there are no tears in the CV boots, the suspension linkage appears to be in one piece. So the creaking may or may not be related to the dent.
I'm taking it in this Saturday to have the damage looked at, but before I go in I'm hoping to find out what may be causing the creaking so I have a general idea of what to expect to pay for repairs. I've read everything from the chassis may need to be lubed to CV joints need to be replaced.
Any help is greatly appreciated.
Jul 6, 2015 at 1:50 PM
MHPAUTOS
  • 31,937 POSTS
You may have a split or broken suspension bush, this should be checked out by a mechanic first hand.
Jul 6, 2015 at 2:24 PM
MIDWEST-DAVE
  • 22 POSTS
Okay, is that something that's okay to drive on for another week or so before I take it in to the shop?
Jul 6, 2015 at 2:49 PM
MHPAUTOS
  • 31,937 POSTS
This is one of those things that is hard to say, if it is a worn ball joint it may not last the distance but a bush should be ok, I would get it checked ASAP as your safety is what is at stake here.
Jul 7, 2015 at 1:44 AM
