Crankshaft sensor wiring diagram needed?
2015 CHEVROLET SILVERADO
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ALEX OLVERA
Have one wire is connected to the connector (purple with blue) but two of them came off which is one green and the other one black with purple where do they go?
Nov 7, 2024 at 9:58 AM
Sure, here is the crankshaft position wiring diagrams and connector views so you can get the wiring repaired correctly, check out the images (below). Let us know if you need anything else.
Nov 7, 2024 at 6:36 PM
ALEX OLVERA
Okay, thank you! Just one more thing, on my connector is 123 so the black with purple would be in middle and the green on the side is that fine?
Nov 8, 2024 at 8:27 AM
The green wire is one the right side of the connector as you look at it with the safety clip on top.
Nov 8, 2024 at 10:37 AM
ALEX OLVERA
Thank you! I appreciate it!!
Nov 8, 2024 at 11:33 AM
You are welcome, please use 2CarPros anytime we are here to help.
Nov 9, 2024 at 10:47 AM
