Okay, so here's what happened: the harness side coming from car side of harness to crankshaft sensor is messed up. I'm not even sure where or how far back it goes but it looks like it's going to be hard to trace. so, i wanted to just use butt connectors and crimp the wire, but I'm noticing some foil looking sheathing or wrap. I'm wondering what that is and how important it is. It's so fragile and thin it just keeps breaking apart. And i can't tell if I'm seeing some sort of green very thin wire or not. what's this for? And how important is it to be connected for the sensor to work? Can i get away with just connecting the 3 main wires? And if it's needed is there anything i could use in that area to substitute? I have foil HVAC tape or aluminum foil as options but I'm not sure if that's a good idea. would appreciate some clarification on this. thanks
Aug 21, 2022 at 9:47 AM
