My vehicle has three wires for the crankshaft sensor. One day I got a crankshaft error on my scan tool. So I went to replace the sensor. When I was taking out the sensor the wires came out of the harness. I called my local Kia dealer and asked them what order the wires go in and the told me the wrong order. So I bought a service manual and found the right order. But now I get 5 volts on the signal wire that comes from the ECU. I'm pretty sure that the 5 volts should be coming from the sensor to the ECU. So on the three wires I have 12 volts, 5 volts and the ground. When I hook up the harness to the sensor I get 12 volts across all three wires. I have replaced the sensor four times. I have disconnected the harness to the ECU and checked the pin for the sensor on the ECU and it has .75 volts. I checked the harness and no volts on it. But when I connect the harness to the ECU I get 5 volts when the car is on the on position. I have replaced the wire harness to the crankshaft sensor and the same thing happens. I think the ECU may be bad but the I don't understand why the sensor harness has 12 volts on all three wires only when the sensor is hooked up. I have tested the sensor by putting 12 volts into the relay wire that's supposed to have the 12 volts and all three pins on the sensor has 12 volts. I even test the new sensors and the same thing happens. Please help
Jan 18, 2019 at 12:52 PM
