Good evening.
Picture attached and procedure.
Removal and Installation:
1. With the vehicle in neutral, position it on a hoist.
2. Remove the left hand catalytic converter.
3. Remove the bolt, nut and the heat shield.
- To install, tighten to 10 Nm (89 lb-in).
4. Remove the rubber grommet cover.
5. Disconnect the crankshaft position (CKP) sensor electrical connector.
6. Remove the bolt and the CKP sensor.
7. To install, reverse the removal procedure.
Apr 5, 2018 at 5:37 PM
