I doubt the crank sensor is the cause of a high idle. Rough idle, misfires, and no starts are common with a bad CPS.
High idle is usually a vacuum leak or sticking IAC, those let extra air into the engine that does not get measured by the ECM and you get a high idle. A small leak will not effect the engine once it gets off idle.
Testing for a vacuum leak is not difficult.
Sep 24, 2017 at 6:09 AM
