Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Nissan
Hardbody
Engine
Crankshaft
Sensor
Replace/Remove
Still will not start after replacing crankshaft sensor
1997 NISSAN HARDBODY
180,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
HANNAH RHOTEN
MEMBER
1 POST
FOLLOW
I replaced the crankshaft sensor but it still won't start.
Jan 13, 2021 at 1:41 AM
CERTIFIED EXPERT
Good morning,
I would check compression to be sure there is no internal timing issue.
Can you hear the fuel pump run with the key on?
Do you have spark at the plugs when cranking?
If you have a tachometer on the dash, check and see if the RPM shows a reading while cranking. That will tell us if the crank sensor is sending a signal to the ECM.
Jan 13, 2021 at 2:11 AM
