Turning over slowly and not getting gas could be related but they don't have anything to do with the crank sensor. The crank sensor just tells the PCM when the engine position is so it can fire the plugs at the right time.
Let's address the slow crank first and then the fuel issue. First, how do you know it is not getting fuel?
Then we need to check the battery to make sure it is properly charged because this is the most likely cause of a slow crank.
Here is guide for the crank sensor just to explain it. Let me know about the battery and how you know it is not getting fuel and we can go from there. Thanks
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Oct 11, 2019 at 6:52 PM
