If you got a crankshaft position sensor trouble code, that does not always mean the crankshaft position sensor is bad, the error code only refers to that crankshaft position sensor circuit, it could be the wire, a loose connection, etc.
You need to post the code you are getting and then we can probably provide you with a trouble shooting chart for testing them sensor circuits,
Jan 8, 2018 at 9:12 AM
