Hello everyone! I also come with a question but also a request to help me with this problem with the crankshaft sensor (the one on the engine block at the back of the engine)
I selected Renault Master and Opel Movano (they are the same. The connector that comes to the crankshaft was damaged, I ordered a new connector but it came with all 3 yellow wires, I have 2 brown wires and 1 blue wire on my car, I checked each wire separately the blue one is the ground, 1 brown wire has 5v it should be the power supply and 1 brown wire has approximately 4.5v it should be the signal but I don't know in what order they are connected, the sensor has numbered pins and the new connector is the same I will leave you the product code of the sensor and if someone can help me with the order of the wires I am very grateful and thank you in advance
Cod OE sensor 237310300R.
I also uploaded a picture of the sensor.
Jul 17, 2025 at 7:10 AM
