Crankshaft sensor where is it located?
2005 VAUXHALL CORSA
70,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
PETELANG
I am trying to replace the crankshaft sensor on a 1.4 automatic Corsa design. I cannot locate the sensor. Internet and manual sources say rear of engine near bell housing but it’s not there. There is a sensor on the front below the oil filter, could this be it?
Help much appreciated.
Mar 29, 2025 at 2:34 AM
It says the crankshaft sensor is near the oil filter. The crankshaft sensor is mounted on the rear of the engine block, below the intake manifold, and just above the oil filter housing. Check out the images (below). Let us know if you need anything else.
Mar 29, 2025 at 4:39 PM
PETELANG
I eventually found it as you say under and slightly left of the oil filter but on the front not rear of the engine.
Mar 31, 2025 at 12:41 PM
Okay, gotcha, nice work, the info on Vauxhall is a little sketchy.
Apr 1, 2025 at 8:48 AM
