Crankshaft pulley dampener woodruff key missing
1995 FORD EXPLORER
236,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
95FORDEXPLORER
My vehicle has a new OEM engine, 10000 miles ago and fully rebuilt transmission It was running fine, no vibrations, no alternator problems, no steering problems, etc . It just need EVAP fix for smog testing in California. They got this done and did it well by taking a 1996 front hose assembly and turning it into a 1995.
My mechanics found a front crankshaft oil seal leak.
They advised replacing the seal and the belt since the oil had leaked on it .
They now say there was no woodruff key when I brought it in and that they cannot get a replacement key installed without $990.00 of labor to remove everything one would remove to change the timing chain. They say part of the access problem is four wheel drive parts.
They say it could be catastrophic failure if the key is not in of power steering, alternator, water pump just going out without symptoms should the pulley start just spinning because the key was not there to prevent failure.
Is it possible that there was no key to start with if the engine did not vibrate, the water temperature gauge never moves in city driving, the alternator and battery were replaced and have been working fine?
Is there a special trick to get a 1995 Ford V6 4wheel drive key installed???
Is it possible that $990.00 of removing parts for better access would make it possible to get the key installed anyways?
Help! my car seemed fine and now I am confused and wondering if I should even consider paying the $990.00 to have a safe car!
Dec 15, 2017 at 1:27 PM
CARADIODOC
  • 34,306 POSTS
I would get a second opinion. I am not familiar with this job on your vehicle, but removing and replacing the vibration damper on my 1988 Grand Caravan takes about a half hour. Yours calls for 1.3 hours on a four-wheel-drive model, with an additional 0.4 hours with air conditioning. If you add time for driving the vehicle into the shop, doing paperwork, and possibly even modifying a generic key to fit, the job should take perhaps as much as 2.5 hours.
The front seal is listed separately in the flat-rate guide at 1.4 hours, but it is not clear if that is in addition to the vibration damper removal or if that includes both jobs.
Dec 15, 2017 at 4:43 PM
