To line the dot up with the T the carter key is pointing straight down, in your comment it said carter key should be pointing straight up? How many revolutions of the spline crank constitutes an compression and exhaust stroke? Am I in time with the carter key down and the dot on the T (TDC)? Thanks man, this is brutal!
Feb 11, 2020 at 11:07 AM
