Crankshaft pulley
2005 CHRYSLER PACIFICA
168,000 MILES
ZELLDOG93
  • 111 POSTS
Went to remove crank pulley and my puller pretty much shattered i believe there is approximately 1/4 inch of the puller in the bolt hole and about 1/2 inch sticking out that is angled i tried hitting it out but was not successful any tips are appreciated with removal of broken puller and pulley.
Sep 20, 2017 at 1:37 PM
MHPAUTOS
  • 31,937 POSTS
can you up load a picture or video so i can see exactly what you are facing?
Sep 21, 2017 at 3:50 AM
ZELLDOG93
  • 111 POSTS
this is what i have.
Sep 21, 2017 at 2:02 PM
Can you show us a picture of the puller please? I think you might have been using the installer. Did it thread in? if so then that was the installer.
This video of how to remove broken bolts will help.
https://youtu.be/YDt5OUIZTs0
Sep 22, 2017 at 1:01 PM
ZELLDOG93
  • 111 POSTS
I used a 3 claw puller
Sep 22, 2017 at 1:15 PM
ZELLDOG93
  • 111 POSTS
It did not screw in
Sep 22, 2017 at 1:16 PM
MHPAUTOS
  • 31,937 POSTS
have you applied any heat to the pulley boss to help expand it while applying pressure?
Sep 22, 2017 at 4:52 PM
ZELLDOG93
  • 111 POSTS
I have
Sep 22, 2017 at 5:44 PM
MHPAUTOS
  • 31,937 POSTS
go get a steering wheel puller, they are small and fairly strong, you will have to drill and tap two holes or the pulling bolts and clean up the centre boss bolt so the mandrel sits flush, apart from this you will have to drill a series of small holes and split the pulley off, i would have thought heat and pressure would have moved it.......
Sep 22, 2017 at 6:57 PM
ZELLDOG93
  • 111 POSTS
Awesome I am going to try that next time I am at the shop I was rather impressed that it didn't move with heat
Sep 22, 2017 at 9:27 PM
MHPAUTOS
  • 31,937 POSTS
It must be tight... with it loaded up on the puller apply some heat as well as that will
Help
Sep 22, 2017 at 9:56 PM
