As soon as I press the gas pedal it bogs down
1992 PONTIAC TRANSPORT
173,023 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ERICS1933
Car starts up fine as soon as I press the gas pedal it bogs down and does not want to go past 2000 RPM's and almost shuts off. Crankshaft position sensor, throttle position sensor?
Oct 4, 2018 at 3:25 AM
Good morning.
I would check the fuel pressure first. Low fuel pressure would cause this issue.
Check the catalytic converter. A clogged catalytic converter will also cause this issue.
I would start with these two items first.
No to the TPS and crank sensor.
Are there any codes?
Oct 4, 2018 at 4:23 AM
