Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chrysler
Sebring
Engine
Crankshaft
Sensor
Replace/Remove
Crankshaft position sensor relearn procedure?
2009 CHRYSLER SEBRING
201,311 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NIGEL331
MEMBER
1 POST
FOLLOW
How can I manually, without using a scanner, do the relearn procedure for a newly installed crankshaft position sensor?
Feb 2, 2024 at 12:40 PM
CERTIFIED EXPERT
On this vehicle, there is no relearn when you replace the crankshaft position sensor. Are you having trouble getting it to start after the repair?
Let me know. Also, if it isn't starting, check if there is spark at the plugs. If the CKP is a problem, there won't be spark.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Feb 2, 2024 at 9:48 PM
